Author Topic: ScrobblerBrainz: a plug-in to scrobble tracks to ListenBrainz  (Read 26485 times)
karaluh
It's so fresh that it's still hot, it's not yet well tested even by me and has several restrictions:
1. As I said it's not very well tested, I just created the first version.
2. Breaks when there are issues on ListenBrainz side. If suddenly a dialog box appears with some errors regarding ListenBrainz I would very much like to get the full error message from you.
3. No MBIDs in the scrobble, MusicBee doesn't expose them in the API. I might be able to workaround it using custom tags, but if that fails I would have to read tags for each format supported by MusicBee myself which would be A LOT of work.
4. No offline scrobbling, all scrobbles are lost when there's no internet.
5. No playcount sync.
6. No "now listening".
7. Or any other feature the last.fm scrobbler has.
You can see the code, report bugs, etc. on GitHub. Also, since this is my first C# project a code review would be much appreciated. I'm also not sure if the licence can be GPL, if that's not the case please let me know.
https://github.com/karaluh/ScrobblerBrainz
The compiled plug-in is here:
https://drive.google.com/file/d/12dWSnoFBPjrp9jsBl19CXC6UJN9k6G-r/view?usp=sharing
To be able to use it you obviously need a ListenBrainz account. The plugin requires your user token to be able to submit scrobbles which you can get here https://listenbrainz.org/profile/
Last Edit: December 18, 2022, 07:47:54 PM by karaluh
ListenBrainz plugin for MusicBee:
karaluh
I just released another alpha (link below) which is much more stable. I'm scrobbling in parallel to last.fm and ListenBrainz and am actually getting higher scrobble count in ListenBrainz. That's probably because I'm scrobbling very short tracks also, which the last.fm plugin doesn't seem to be doing.
Please note that there is still no offline scrobbling so in case of issues with your internet connection or ListenBrainz internal problems your scrobbles will be lost.
And here's the link to the download:
https://github.com/karaluh/ScrobblerBrainz/releases/download/v0.0.2-alpha/mb_ScrobblerBrainz.dll
karaluh
HisMessengerDAB
This is pretty amazing! Way to go man. I appreciate your hard work
karaluh
Thank you for your kind words, I'm glad you've found the plugin useful.
HOX
Still on earliest version and no bugs whatsoever lmao. Anyway i will install newest and thank you for hard work. ListenBrainz have nice stats, imo it's going to be better than last.fm
Rotom
v1.0.0 works with WINE too. Thought I should let anyone here using MusicBee via WINE know.
Eggaian
  • You all know exactly who I am. Now, say my name.
Hi. Love your plugin but I have a couple questions: why are some of my listens for some artists split into two separate ones? one with a musicbrainz entry and one which doesn't? is this related to what you address in your first post as 'MBIDs'?
Thank you for your work.
Last Edit: September 10, 2021, 01:40:03 AM by Eggaian
karaluh
That's interesting, can you share a link to your ListenBrainz profile so I can investigate? And thank you for your appreciation.
karaluh
Thank you all for your appreciation, this really keeps me going :) There's a new release, it fixes some UI issues with the settings panel.
https://github.com/karaluh/ScrobblerBrainz/releases/download/v1.1.0/mb_ScrobblerBrainz.dll
Eggaian
Hello. My username is Diaken but by looking around I realised the artists from which some of my listens are split into two don't have a musicbrainz entry for some of their releases. So, I end up having a separate playcount even though they are plays from the same artist.
The only solution I see is creating those missing entries for the releases. Or what else do you think could be done?
Also, I downloaded the new version of your scrobblerbrainz but it says it's still version 1.0.0.0
karaluh
If your profile is at the link below then you have to be more specific because I don't see MusicBrainz-linked scrobbles there.
https://listenbrainz.org/user/diaken/
As for the version number, where exactly does it say its 1.0.0?
