Author Topic: ScrobblerBrainz: a plug-in to scrobble tracks to ListenBrainz  (Read 26398 times)
Fabland
Bonjour,
j'ai installé votre plug in, mais rien ne se synchronise.
J'ai reset le jeton, mais malgres tout rien..
Auriez vous une idée.
Merci
Hello
I've installed your plug-in, but nothing syncs.
I reset the token, but still nothing.
Do you have an idea?
Thanks
karaluh
When you open the settings, is your LB user token saved or is the field empty?
ListenBrainz plugin for MusicBee:
https://github.com/karaluh/ScrobblerBrainz
ChuChu
When I listen to a track offline, a JSON file is created in AppData/Roaming/MusicBee/ScrobblerBrainz/Scrobbles, but the scrobble is never added to ListenBrainz after I connect to the internet. I have to manually add it myself. Is this how it is supposed to work?
karaluh
Offline scrobbles are re-submitted only on startup. Restart MusicBee after connecting to the internet and all the offline scrobbles should be automatically submitted.
