Author Topic: show whether the file is in inbox or library within the playlist  (Read 565 times)
arbor_mute
when I search something, there is a column that shows whether the file is in inbox or library.
is there any way to display this column in the playlist?
Thank you
Not with the icon IIRC, but if you display the field "Category" it'll says Music or Inbox
