Some screenshots would be helpful. Have you looked at the tag inspector to verify if Picard actually inserted any tags.
Quote from: psychoadept on April 15, 2020, 03:23:46 AMSome screenshots would be helpful. Have you looked at the tag inspector to verify if Picard actually inserted any tags.Solved. I defined a tag code in the custom tags etc. The problem was that MB needed to re-scan the library to make them show etc.
