Author Topic: remove duplicate music files?  (Read 3320 times)
btoven23
New MB user- is there a way to remove duplicate music files within albums?
Thanks for any help.
You can use the Duplicate Manager in the tools menu to identify them, although personally I would recommend putting them in a playlist rather than automatically deleting.  You can select the ones you want to delete in the playlist.
