Author Topic: Shoutcast Stations No Longer Conencting  (Read 2221 times)
musicbee4dwd
I can't get MB to connect to any Shoutcast streams. Other streams are fine.
Any ideas?
e.g., anything from http://yp.shoutcast.com won't stream. I keep getting the BASS error.
I get the same and also the same when using winamp itself - the stations are returning 503 - service temporarily unavailable
while connecting to shoutcast is still slow and unreliable, I have been able to create a version that seems to be working
musicbee4dwd
I found my favorite station, a jazz station, here:
https://www.relaxingjazz.com/
He has some streams three that I tried, but they didn't work.
e.g.,
https://www.relaxingjazz.com/rj128k.pls
https://tunein.com/radio/RelaxingJazzcom---Smooth-Jazz-s111775/
https://www.relaxingjazz.com/broadband.asx
Is there anyway I can use those in MB other than creating a new station and inputting the stream manually, like I did? I think maybe his stream is just dead.
BTW I can't find the above favorite jazz station in shoutcast anymore, unless he changed the name.
Is this a MB problem, or something else? I see there are listeners so someone is able to connect.
Thanks for the fast reply.
PS--Tried the new files. Still, most SC stations are tossing errors. Icecast is fine.
Last Edit: March 28, 2020, 05:13:08 AM by musicbee4dwd
i dont see relaxing jazz as a station in the shoutcast directory but manually creating a radio station using https://www.relaxingjazz.com/rj128k.pls works fine for me
try re-downloading the patch file
musicbee4dwd
Hey Steven, thanks.
I tried your pls link and it didn't work.
Copied and replaced files in this directory:
C:\Program Files (x86)\MusicBee\
This is strange.
Working here with 3.4.7390 P (before the patch posted in this thread) and no issues.
musicbee4dwd
Well, something is wrong on my end then, but I have no clue how to fix it.
Last Edit: March 28, 2020, 05:46:17 PM by musicbee4dwd
