Using 3.3.7367 P when in Computer Node, selecting all tracks in a directory and moving them (via dragging) the selected directory disappears (expected) and the selector goes to the top of the Computer Node. Previously the selector would move up one directory (or perhaps it moved down one directory.)
I'm not sure if this behavior is a bug, an oversight, or the new expected behavior. If the latter, I'd like to request that it revert back to the way it was previously. Example: Let's say I have a five disk album with each disk in it's own directory. If I were to volume analysis and the entire album (let's say from the Inbox) each disk would be analyzed individually. So after I add the disc and track number tags, I moved each disk to the directory of the first disk. After each disk is moved, the new (current) behavior has the selector jump to the top of the node. This causes me to either manually scroll through thousands of artists to get back to the album I'm working on, or go back to the Inbox > right-click > Search > Locate in Computer Node.
The timing of this might go back to when the confirmation dialog was added as a warning when moving files. I can move this to the Wishlist if this is the new expected behavior.
Thanks.
