Author Topic: Auto-DJ Cache Question.  (Read 1232 times)
#1Gamemaster
I was just wondering if there is someway of automatically scanning and caching all of the artist data from last.fm that Auto-DJ uses. The only reason that I wanted to know is because I use the portable version of Musicbee off of a flash drive on my work computer and for some reason last.fm has recently been blocked so all I can use when I'm there is any data that has already been cached. So if there is a way to do so I'd like to run that on my computer at home so that I'd have it with me at work.
Artist data is cached in the musicbee appdata/InternalCache/ArtistData folder. Just copy the contents from your PC to your other one into the same folder
#1Gamemaster
Don't you need to start up an Auto DJ mix for an artist for that data to be cached or is it supposed to create artist cache data when your library gets scanned in?
Because I did find some of the artist cached data but only to ones that I've already started a mix to. Which when I copy that data over it does allow me to use that part of auto DJ even without a network connection but only for the artist that I have a cache file to.
