Author Topic: Radio support enhancements  (Read 14938 times)
TerDale
Hi Steven,
Discovered MB quite recently, and really think it as a terrific audio player, thanks a bunch for this!
One thing I miss about radio support, is the capability to set the radio web site in the settings of a radio, indeed some radios don't send the playing artist name, and sometimes going to their web site you can get this information. Along with the capability to set the URL, a way to go to the web site should also be provided: a possibility is to have the content of the to-be-created "Web site" column clickable. But I'm pretty sure you'll get other better ideas.
TIA
for the next update, i've added a new setting in the radio station config dialog to specify a web-page and an option to automatically open the page in a tab when the station is played
TerDale
Quite coool!  :) Thanks Steven.
MB is really terrific: great app, great and prompt support.
this has the change to support automatically opening a track playing page for the station (set in the station editor dialog)
http://www.mediafire.com/?1i4c1cu3uvnun67
TerDale
Thanks Steven, I'll test it ASAP, and will let you know.
TerDale
Hi Steven,
Works fine, as I expected. Thanks again.
there was a mistake with that version for Auto-Tagging sources (MusicBrainz), so you should use the last version i posted which fixed that and check your Tags(2)/ tags providers
http://www.mediafire.com/?6ur8b62cja4wkba
TerDale
i would like to but there is no API to extract the data and i see they sell a radio player with it, so i guess thats how they make their money and wouldnt want anyone getting the data
kstuart
5: (If possible) Configurable prebuffering, buffer size and prebuffering after underrun.
I could use these enhancements also (since I am currently using Winamp in order to be able to increase the buffer size and even foobar2000 does not support it despite occasional requests).
