recently i was playing few songs on Potplayerand it sound perfect to me.with musicbee bass is bloaty according to my taste(nothing wrong with musicbee).i try to change settings i could with Musicbee but couldn
Do you experience that with lossless (e.g. flac) files, or with mp3, or something else?
MusicBee will output bit-perfect if you have your settings right.
Potplayer should too.
And I believe they even advice against using something else than the onboard pre-installed decoders.
So out-of-the box there should not be any difference in sound quality at all, and there would be no sensible explanation for it if somebody stated that they do sound different.
So I am guessing here that you made some changes to Potplayer and it is not using the default settings and decoder anymore?
Why?
Maybe other members have some useful suggestions, but all I can think of is that either in MusicBee or in Potplayer you have set/changed something that prevents bit-perfect output.
