That depends on which version you're currently using and which version you're going to install. Portable to Portable would be the easiest and as long long as you only replace the the files in the ZIP, there should be no data loss. But you should make backups just in case.
Also, please try to make your subject line a little more descriptive. You started two threads with the subject even though they deal with different topics. I changed this one for you.
