Author Topic: Multi-select in Search & Replace window  (Read 907 times)
JMuller
It'd be really nice to be able to select and deselect multiple items at once in the Search & Replace window. As is it's too tedious to use in a case as illustrated below.
It looks like Search and Replace only works on any tracks selected in the main Library view when it is run.
So you could perform a search first (e.g. Artist contains '&') and then select the tracks you want to update there before selecting Search and Replace.
JMuller
Didn't think of that, thanks. It's a fairly roundabout way of achieving the result but it works.
