Author Topic: Newbie here, stuck on tutorial  (Read 7367 times)
2MuchToo
Hi!  Thanks to Steven and this community for the great player app.
I am interested in making a plugin.  I'm a total C# newb and it's a few years since I did coding at all. So I've been following the tutorial, but got stuck.  I believe the issue is where methods belong in the code, specifically createMenuItem() and MenuClicked, and/or the call to mbApiInterface.createmenuitem()
If I have the createmenuitem call in the Initialize method as per the instructions (highlighted), then
If createMenuItem() and MenuClicked are outside the Initialize code block, I get “Unreachable code detected”.  Everything still runs but there's no menu created.
If the 2 methods are inside the Initialize code block I get “The modifier private is not valid for this item.” Again it doesn't crash but no menu.
If I put mbApiInterface.createmenuitem() outside of Initialize method, I get “The name mbApiInterface.createmenuitem() does not exist in the current context.
I imagine this is a very simple error related to the flow of the code, but I am stumped. If someone could point me right it would be much appreciated!
Thanks!
karaluh
Same issue here. The code compiles, there are no warnings, but there is no menu entry either.
namespace MusicBeePlugin
    public partial class Plugin
        private MusicBeeApiInterface mbApiInterface;
        private PluginInfo about = new PluginInfo();
        public PluginInfo Initialise(IntPtr apiInterfacePtr)
            [some default code removed]
            createMenuItem();
            return about;
        private void createMenuItem() {
            mbApiInterface.MB_AddMenuItem("mnuTools/Start My Plugin", "HotKey For Start My Plugin", menuClicked);
        private void menuClicked(object sender, EventArgs args) {
            Form1 myForm = new Form1(); myForm.Show();
ListenBrainz plugin for MusicBee:
https://github.com/karaluh/ScrobblerBrainz
karaluh
My issue was my stupidity. I forgot to enable the plugin :P
Briter
LOL I have the same problem. (Solved)
It was API calling. You call an API before the API calling.
You need to use "createMenuItem();" after "mbApiInterface.Initialise(apiInterfacePtr);" in Initialise method.
Yeah. That's all. EZ fixed.  8)
