Author Topic: how to create own panel in panels configuration?  (Read 5882 times)
Sorry, I don't think I understand the question. If you just want to add the panel, check the box. It will move across and you can adjust the position by dragging it up or down.
  • MB Version: 3.6.8830 P
If you are creating a plugin and want to be able to add a panel, have a look at Eincrou's Chapter List plugin here.
It works that way.
