Author Topic: Super Combo Enhanced (modified spandan888 skin)  (Read 15151 times)
Galious
I hope slight editing of existing skins is not frown upon here.
I adjusted the Super Combo skin by Spandan888 to be more to my liking (optimized for 1920x1080, not tested in other resolutions):
- smaller clock, moved to bottom-right corner
- play controls moved to left
- next tracks moved left
- lyrics are now along the right edge of the screen to accomodate a higher number of lines
- smaller title to accomodate longer text
- added loved track icon to current and next tracks
- added artist gallery with picture changing every 30s
Link to larger picture
Download link (please rename to .xml afterwards)
spandan888
thanks buddy  :D  :)
this made me happy!
8) Get the BIGradientz Theater Mode.  8)
MikeMail
Can't seem to get the download link to work.  Get this message:
Your request is blocked due to invalid referrer. If you are trying to hotlink this page, please use: https://pastebin.com/raw/DmsdS16G
Am I doing something wrong?
   -=- Mike
Not sure what's wrong with the other page, but you can download it from the second link they gave. Just save it as an .xml file.
pullapint
I'm getting the same error as above when clicking the link on the download page. I'm redirected and get the error:Your request is blocked due to invalid referrer. If you are trying to hotlink this page, please use: https://pastebin.com/raw/DmsdS16G.
Ive also tried d/l from link on this page.
That link doesn't work for me either, but https://pastebin.com/raw/DmsdS16G does.
Copy what it displays, paste it into a text editor and save the file as an .xml.
Odd - it's not working for me now either.
No need to even do that. Click the link to display the xml > File > Save as > filename.xml
Done.
zan5hin
G'day, I tried this skin and saved the file as XML from pastebin.  But there seems to be some cropping issues on the text, please see screenshots:
https://imgur.com/a/0hVHbca
For reference, I'm playing with Theatre mode skins for a new living room setup I'm putting together with a Samsung OLED tablet running windows, connected to high end DAC, power amp and floorstanders to then output theatre mode via HDMI to 24" 1920x1080 screen or 55" 4K OLED.
