Author Topic: Super Combo Enhanced (modified spandan888 skin)  (Read 15441 times)
Galious
I hope slight editing of existing skins is not frown upon here.
I adjusted the Super Combo skin by Spandan888 to be more to my liking (optimized for 1920x1080, not tested in other resolutions):
- smaller clock, moved to bottom-right corner
- play controls moved to left
- next tracks moved left
- lyrics are now along the right edge of the screen to accomodate a higher number of lines
- smaller title to accomodate longer text
- added loved track icon to current and next tracks
- added artist gallery with picture changing every 30s
Link to larger picture
Download link (please rename to .xml afterwards)
spandan888
thanks buddy  :D  :)
this made me happy!
8) Get the BIGradientz Theater Mode.  8)
MikeMail
Can't seem to get the download link to work.  Get this message:
Your request is blocked due to invalid referrer. If you are trying to hotlink this page, please use: https://pastebin.com/raw/DmsdS16G
Am I doing something wrong?
   -=- Mike
Not sure what's wrong with the other page, but you can download it from the second link they gave. Just save it as an .xml file.
Latest patches (3.5/3.6)
pullapint
I'm getting the same error as above when clicking the link on the download page. I'm redirected and get the error:Your request is blocked due to invalid referrer. If you are trying to hotlink this page, please use: https://pastebin.com/raw/DmsdS16G.
Ive also tried d/l from link on this page.
That link doesn't work for me either, but https://pastebin.com/raw/DmsdS16G does.
Copy what it displays, paste it into a text editor and save the file as an .xml.
Odd - it's not working for me now either.
No need to even do that. Click the link to display the xml > File > Save as > filename.xml
Done.
zan5hin
G'day, I tried this skin and saved the file as XML from pastebin.  But there seems to be some cropping issues on the text, please see screenshots:
https://imgur.com/a/0hVHbca
For reference, I'm playing with Theatre mode skins for a new living room setup I'm putting together with a Samsung OLED tablet running windows, connected to high end DAC, power amp and floorstanders to then output theatre mode via HDMI to 24" 1920x1080 screen or 55" 4K OLED.
