Author Topic: inbox and remove file  (Read 2034 times)
urfausto
why, if i set add new files to inbox, the message i get when i remove one file says "remove from library"?
The use of “library” in MusicBee is a little fuzzy. In this case, library refers to any files that have been scanned into your database, so including Inbox, Audiobooks, etc
Latest patches (3.5/3.6)
urfausto
jeez, then how do you distinguish from library and inbox?
There's a "Mail" icon next to tracks in your inbox and a music note icon next to tracks in your library.
urfausto
nice, but i don't see this...  :( how do i set it?
They show when you do a search.
If you're looking at a playlist, right click the file and select "Send To." Whichever option is greyed-out is where the file is.
Where else are you having trouble determining which files are in the Inbox and which are in the library?  Everywhere else it's pretty self-explanatory (i.e. if you're looking at your library and you see the file, it's in the library / if you're looking at your inbox and you see the file, it's in the inbox).
You can also display the Category tag to see this.
I did not know this. Thanks.
urfausto
ok i've finally found the tabs for library and inbox. d'oh.
still don't know how to see those icons but ok...
Last Edit: February 29, 2020, 09:27:13 AM by urfausto
The icons show up if you're doing a search of your whole library.
urfausto
oh yeah i see this just now, in the search box you can change the search spectrum to the entire stored music
