Cool skins! How did i add that cool little visualizer on the right (the one above the volume slider)?Thanks!
You need to arrange the various panels to your liking. Panel Arrangement options can be found by clicking the box to the left of the search bar. Drag and drop various elements from the right side to the desired panel on the left. Specific elements can be dropped on any panel that shows a red bar when clicking an element.
Found it! It's the compact grid option that I like. Is there a way to add ratings/play counts to this view?
Or is there a way to add the album header field to the 'detailed list' option?
Quote from: snively on March 12, 2021, 03:51:57 PMFound it! It's the compact grid option that I like. Is there a way to add ratings/play counts to this view? I don't think so.QuoteOr is there a way to add the album header field to the 'detailed list' option?Not sure what you mean, it has a header by default (grouping header) and you can customise that to your liking.
this skin has the main panel how I'm trying to get mine setup but I cannot figure it out. How did he get ratings in the compact view?
