I can't find a way to do this, would you know if it's possible:
Copy tags only from x:\artist_title.mp3 to y:\artist\album\artist_album_title.mp3
I use another player, Serato, that analyses a file and adds/updates tags. I'm wondering if there is a way that MB could find the same file (though with a different name) through the standard, artist/title/etc tags, in the x:\ location and copy the tags only from that file into the file in the y:\ location.
Found this info on Serato forum :
General Encapsulated Object (GEOB) tag. This isn't a typical tag and most (if any?) programs cannot show/display this info.
Cue points, loops and overview info is stored in the (GEOB) party of the ID3 tag. You cannot physically see it change it manually, so clearing basic fields (artist, comments etc) is safe.
I don't know if Searto uses the default BPM tag too.
Also, while I'm asking:
Can MB 'send to/play with' another app, Serato, where I can listen to, audition, analyse and update the file. Then, I close the file in Serato and MB will immediately show the tag changes in it's library.
Scratch this, just found the 'Tools' menu option, will see if this works with Serato.
And, the option to constantly monitor my music folder.
