Quote from: phred on February 20, 2020, 02:47:35 AMSorry to say I still haven't had the time to test this new patch, but I should be able to later on Thursday.I have removed a track from a playlist and then performed a sync of that playlist. I'm still seeing Windows convention for the slashes, in other words, a forward slash (/). In other words, no change observed in the text file. Not a problem for me, but just wondering why I'm not seeing backward slashes in the playlist. Using M3U.This is with 3.3.7354 P which was the patch posted in this thread. FYI, it's the same version number as what I was using previously and downloaded earlier that day.
Phred - Are you sure you didn't mix things up? A forward slash is the unix convention. The result you saw of the playlist with forward slashes is the desired result and what's now working for us on android 10.
The library preferences for playlists only applies to library playlists and not to device synching.Could you try this version which uses the unix convention for filenames in playlists:https://getmusicbee.com/patches/MusicBee33_Patched.zipunzip and replace the existing musicbee application files
