I was working with MusicBee and when I switched two of my playlists, from JCS to QR, I received this unexpected error:
MusicBee v3.3.7165.34284 (Win10.0), 18 Feb 2020 10:58:
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at #=zqUJ7kvLa9PI5TPaQDLmb34k=.#=z2y3a5E8fi3od.#=z5_E11LYc9XNL()
at #=zqUJ7kvLa9PI5TPaQDLmb34k=.#=z2y3a5E8fi3od.#=za5iVs0g=(Boolean #=zy_A6nrJnO2s8)
at #=zxSs8$Zj1YyE$QLYKTW9wh8Od34QB.#=zH0203Sppqq2d.#=za5iVs0g=(Boolean #=zy_A6nrJnO2s8)
at #=zxSs8$Zj1YyE$QLYKTW9wh8Od34QB.#=zkAHHg4X8wcrz.#=zrzUJhPgh5izz(Boolean #=z5zxsD5LsXdD6)
at #=zxSs8$Zj1YyE$QLYKTW9wh8Od34QB.#=zkh$3YnnZKCF0(#=zfcT6tG2gZ9QydKEZ48ftAuI= #=zEH_hLiGcbNOH, Boolean #=ztqkXonDwgWfA, #=zkuDn43Q= #=zsZOUqYs=, #=zGCa2G8o60ctHh3eDYu_2AWs= #=zM4IQFXtPunJS, Boolean #=ztgHTydpxNIIL, #=zpwYqZMoLK6eVkTssbgy60Ps= #=zmpEIs_HCrunj, #=zxHTiYwJAU2m2nRLCq2wl9Zg=[] #=zR77RdKExxuzF, Boolean #=znK736gt$qlZF)
I, of course, copied it. When I tried to close the error, the same error came up again. I kept trying to close it, but returned as fast as I closed it. I tried to close MusicBee, but it wouldn't close, not even from the Taskbar. I was finally able to close it from the Task Manager.
I was doing a lot of stuff with MusicBee before the error occurred so I don't know how I can give you any more info on it.
I will continue to monitor it for any more errors like this one.
ILvClscRock
