Author Topic: Export  (Read 685 times)
Smudger
Hiya
is there a way please to export either to clipboard or text file the contents from an album to display as follows
1. The Beatles - Help
2. The Beatles - Please Please Me
so to display track no, the artist then dash (-) then track title
thanks in advance
Edit -> Edit Preferences -> Tags(2)...tag handling...'send to clipboard' tags:
<Track#>. <Album Artist> - <Title>
Select Album
Right Click -> Send To -> Clipboard
Boroda's Advanced Tagging & Reporting Tools plugin can do this.
If you'd rather not use a plugin, Preferences > Tags (2) > tag handling > 'send to clipboard' tags.
From the drop-down select the tags you want and format (periods, dashes, etc.) Once that's configured simply select the tracks you want to copy to the clipboard > right-click > send to > Clipboard.
Smudger
