Author Topic: Deleting old files  (Read 1550 times)
Dilligaf
New to this but all my music in my library has been lost so all my stuff on MB is unplayable so my question is how do I delete all the old files in MB and start afresh.? Any help will be appreciated.
Start a new library from scratch File->Library->Create New Library
If you use frankz method, be sure to delete you old library files (the .mbl and so on).
Or you can select the missing files in your current library and hit delete. It may ask if you want to remove them from your drive or just the library. You can say just the library.
