Hi. Sorry for the late reply - life got in the way.
I've created a simple program that will take two lists of tracks and show the differences between them.
I emphasise that this is very simple - I threw it together in a few hours so it doesn't have robust error checking etc.
This is what it looks like in use:
This simple example uses the tracklist from the the Crow soundtrack.
I've exported the tag values to a file and simulated some differences by editing two artist names and removing one completely.
Basic usage:
1. Specify the file path of your exported Spotify CSV file on the left.
(this can also be any text file that has tag values as "artist - track" on each line)
2. Select all the files from your playlist in MusicBee and copy the
<artist> - <title> tags to the clipboard.
3. Click
Paste Tracks to display the MusicBee tracks on the right.
4. Tracks that appear in one list but not the other are highlighted.
I've done it this way because a playlist exported from MusicBee doesn't contain any tag values - it's just a list of file paths.
Because a file name can't be relied upon to be formatted in a specific way it's easier to compare against tag values copied from MusicBee itself.
The program expects them to be copied in the format
<artist> - <title>, so you should set your MusicBee Preferences to copy them that way.
To provide some tolerance for minor differences, comparison of track details is case insensitive and only compares alphanumeric characters.
So:
"Ray Parker Jr. - Ghostbusters" will match with "Ray Parker Jr - Ghostbusters" and
"Bachman-Turner Overdrive - Takin' Care of Business" will match with "Bachman Turner Overdrive - Takin Care Of Business"
The
Grouped checkboxes will group each list by the first letter of the specified sorting column.
The
Reset button just clears any previous tracks from both lists.
The
Artist <> Title button swaps the two values around in case the loaded file was saved with the tags that way.
Hopefully it saves you some time. I don't want to spend a lot of time maintaining or updating this, but let me know how it goes.
Download link:
https://1drv.ms/u/s!Auf1j9D0P6KYhhqitfHWts0lqWAG?e=3UMsj8It doesn't need installing - just unzip and run.
The only system requirement is .NET 4.5.
