Author Topic: Cannot sync with LastFM  (Read 1132 times)
barlet
Trying to sync with LastFM I got the following error (copied from the error log)
12/02/2020 00:28:23 - 10.0.18363.0 - 3.3.7346.39560P - System.ArgumentOutOfRangeException: Value to add was out of range.
Parameter name: value
   at System.DateTime.Add(Double value, Int32 scale)
   at #=z4VG3kz3_stZJTXCKz7012M0OBsFLWvVVeQ==.#=zuVypi0dGIfQTHCjWnQ==()
   at #=z0hU1t27NCSdDuEFG2i9wmLbFI3ZV.#=zUc8xydUFs3Rk(List`1 #=zmm7SkLN6RqHrAHNazD0R1jM=, Boolean #=z8hkV05OmHM1E, Boolean #=zxkrrWAWoHcP5xXED1$HnL5VHUAoa)
   at #=z0hU1t27NCSdDuEFG2i9wmLbFI3ZV.#=z5tv6vW9asliD(Object #=zUcT$s2I=)
Again the portable version is the offending version. The version on the desktop works fine but the one on my portable ssd produces the above error.
I dont think its anything to do with the version. Last.fm simply returned some invalid data. I have put in some handling for the invalid date
barlet
I installed the patch but I regret there is no joy! I hope to have time soon to look into it, maybe it is a bug at my end. Thanks all the same!
i cant believe you are getting the same error. Can you confirm the latest error message from the error log
barlet
The error message in the message box is the same. The error log reports as such;
15/02/2020 03:30:25 - 10.0.18363.0 - 3.3.7347.37375P - System.ArgumentOutOfRangeException: Value to add was out of range.
   at #=zmXrd_5kIMTFeMvS$JHoOrA5aNcE4TAV$8Q==.#=zr0ObD9_7RzHAxB_1bQ==()
   at #=ziRngJbVwyIGONvsoUmibFnOC8_yH.#=zFRZlVJjsjC$k(List`1 #=zaNE_SnYSk7Bct4VN2ohh1QY=, Boolean #=z$FIGF7mo6Wnp, Boolean #=zdKUqkyWyn3Sn0w_loXRIF57Lod1a)
   at #=ziRngJbVwyIGONvsoUmibFnOC8_yH.#=zJG7MDn2hixuW(Object #=zW2QYQYs=)
Thanks Steve. i use the programme virtually everyday and it is a very important tool for me.
This version should work
i think in likelyhood, your last.fm cache file is corrupted so I recommend you delete AppData/LastFmPlayCountCache.dat - expect it to take a long time to resync though
Last Edit: February 15, 2020, 04:40:28 AM by Steven
barlet
Thanks. Deleting the cache did the trick. Thanks for your help and the best audio programme on the net.
