Author Topic: How-to use Winamp as stand-alone visualizer  (Read 22161 times)
Freddy Barker
  • 🎧 MB 3.4.7628P
3 hours later i think i finally got my definitive settings: https://imgur.com/a/CmeysdO
it is absolute killer to me like that. let me know of possible accurate and tested improvements over that one if there can be any. ;)
i'll be checking it out first thing tomorrow, and will report back my findings 🍺
Freddy
[Late night edit]
Before heading for bedding, I couldn't resist a quick look at your transition tab settings, which are now significantly dissimilar to mine, so theoretically should produce a very different visual experience...
Last Edit: February 13, 2020, 10:10:45 PM by Freddy Barker
Freddy Barker
  • 🎧 MB 3.4.7628P
To be honest, I could be fiddling with this until forever, and I have admit that the transition settings you have (from the image) that I tried to today, do make a significant difference to the output, however, I think I will probably stick to my current 'maladjusted' version of the original default, as least for now.
The actual code in the presets, of which there are hundreds, seems effect the reactiveness, a lot..
 If you want to try what I'm using:-
18.0
9.0
2.7
1.8
60.0
About a 1/3rd of the way from 'min'
Disabled hard cuts =  CHECKED
Freddy
urfausto
18.0
9.0
2.7
1.8
60.0
Freddy
disabling hard cuts you don't have to adjust sensitivity because it will not be used, instead you are going only with soft cuts at the given time.
presets activity are independent of preset changes.
Freddy Barker
  • 🎧 MB 3.4.7628P
Maybe I was a little too hasty, I'll go again shorty, this time, with it UN-checked.
I can't always concentrate on the trippy when there's a great tune playing 🎧
Freddy Barker
  • 🎧 MB 3.4.7628P
There does seem to be a marked improvement in the visuals with Hard cuts OFF.
But then some of the presets have a very low or none reactive setting, and when it's their turn to get a milking, you just see a black screen. So I thought I would see which ones they were, so I get get rid.
By pressing F4 key it shows the current preset name..
I found 552 of them in a folder Users\User\Plugins\Milkdrop\*.milk
Then I found 994 of them in another folder. So I moved (instead of copying) them...
Here's the thing...
Everything still seems to work ok. There are new presets I don't remember seeing before 😯
Freddy
urfausto
what does it mean when it it is their turn to get a milking they show a black screen?
You guys are quite buzzzy with this. Out of curiosity: any chance of a gif so we can see how this looks in action?
Freddy Barker
  • 🎧 MB 3.4.7628P
Not one of my videos, but would give you an idea as to what we are looking at, in my case on a 55" TV, while we are enjoying listening to MB playlist..
https://www.youtube.com/results?search_query=milkdrop+2
Freddy
Freddy Barker
  • 🎧 MB 3.4.7628P
Simply that when some of the presets get randomly selected by 'Milkdrop', I only see a blank (usually black) screen, for the duration of that specific preset, when it should be making nice trippy patterns.
I'm hypothesizing that those presets are lacking some bit of code that controls its reaction to the sound output, so I would like to check those out or delete them..
Freddy
Freddy Barker
  • 🎧 MB 3.4.7628P
One of the smaller sized 'preset-name.milk' files, if opened in Notepad, looks like this...Makes fascinating reading! 🤨
[preset00]
fRating=3.000000
fGammaAdj=1.000000
fDecay=1.000000
fVideoEchoZoom=1.000000
fVideoEchoAlpha=0.500000
nVideoEchoOrientation=2
nWaveMode=2
bAdditiveWaves=0
bWaveDots=0
bWaveThick=1
bModWaveAlphaByVolume=0
bMaximizeWaveColor=1
bTexWrap=1
bDarkenCenter=0
bRedBlueStereo=0
bBrighten=0
bDarken=0
bSolarize=0
bInvert=0
fWaveAlpha=100.000000
fWaveScale=0.796897
fWaveSmoothing=0.900000
fWaveParam=0.000000
fModWaveAlphaStart=0.500000
fModWaveAlphaEnd=1.000000
fWarpAnimSpeed=1.000000
fWarpScale=1.000000
fZoomExponent=1.000000
fShader=0.000000
zoom=1.000000
rot=0.000000
cx=0.500000
cy=0.500000
dx=0.000010
dy=0.000010
warp=0.010000
sx=1.000000
sy=1.000000
wave_r=0.500000
wave_g=0.500000
wave_b=0.500000
wave_x=0.500000
wave_y=0.500000
ob_size=0.100000
ob_r=0.000000
ob_g=0.000000
ob_b=0.000000
ob_a=0.100000
ib_size=0.000000
ib_r=0.000000
ib_g=0.000000
ib_b=0.000000
ib_a=0.000000
nMotionVectorsX=0.000000
nMotionVectorsY=0.000000
mv_dx=0.000000
mv_dy=0.000000
mv_l=1.000000
mv_r=1.000000
mv_g=1.000000
mv_b=1.000000
mv_a=0.000000
per_frame_1=wave_r = wave_r + 0.25*sin(1.4*time) + 0.25*sin(2.25*time);
per_frame_2=wave_g = wave_g + 0.25*sin(1.7*time) + 0.25*sin(2.11*time);
per_frame_3=wave_b = wave_b + 0.25*sin(1.84*time) + 0.25*sin(2.3*time);
per_frame_4=warp = 0;
per_frame_5=
per_frame_6=wave_x = wave_x + 0.051*sin(1.23*time) - 0.08*sin(0.2*time);
per_frame_7=wave_y = wave_y + 0.01*cos(1.24*time) - 0.05*cos(0.1*time);
per_pixel_1=thresh = above(bass_att,thresh)*2+(1-above(bass_att,thresh))*((thresh-1.3)*0.96+1.3);
per_pixel_2=dx_r = equal(thresh,2)*0.015*sin(5*time)+(1-equal(thresh,2))*dx_r;
per_pixel_3=dy_r = equal(thresh,2)*0.015*sin(6*time)+(1-equal(thresh,2))*dy_r;
per_pixel_4=zoom = zoom + 0.2*sin(ang*(0.5-rad)*rad);
per_pixel_5=dx = dx + dx_r*5*(rad*sin(time+cos(12*ang)*(0.5-rad))*cos(bass))*sin(time);
per_pixel_6=dy = dy + dy_r*5*(rad*cos(time+sin(12*ang)*(0.5-rad))*sin(bass));
per_pixel_7=sy = sy + 0.7*rad*cos(2-(ang*12)*sin(time)/treb)*dx_r;
per_pixel_8=sx = sx + 0.7*rad*sin(2-(ang*12)*cos(time)/treb)*dy_r;
Thanks Freddy. Are mushrooms included?
Freddy Barker
  • 🎧 MB 3.4.7628P
Only those big flat ones on hot buttered wholemeal toast  ;D
urfausto
Freddy
on the contrary i get completely white presets sometimes, like an excess of light. but i think your problem could also rest upon os and videocard architecture, i'm on win 7 x64 and didn't see almost any black screen
urfausto
anyway, there isn't only milkdrop in winamp, avs is another different huge repository of presets.
Freddy Barker
  • 🎧 MB 3.4.7628P
So there is !, I never really took much notice of that or ever tried it before - it's not bad at all, thanks for the heads-up.
Freddy
