Author Topic: Musicbee crashes on podcast end/start?  (Read 1321 times)
StJason
So I use Musicbee primarily as a podcatcher/player. Lately, it has picked up a really annoying habit. I've set up an auto-playlist of podcasts (actually, several). When it finishes a podcast and moves on to the next, it suddenly crashes. When I restart, it doesn't have the last podcast marked as played.
MusicBee v.3.3.7310 (it did it with the last version as well...)
Windows 10.
Error log only lists some download errors.
are the files downloaded and can you send me a link to your settings file (help/support/view settings)
The issue is the skip silence DSP when used in conjunction with the Tempo DSP, so for now disable the skip silence DSP
StJason
I actually had to shut off both to get it to work. :/
Ah, well. At least it isn't crashing anymore. Thank you.
what if you disable the Tempo dsp but leave the skip silence enabled?
I have found and fixed one issue with the Tempo dsp, so its probably ok to use it with this version.
There is still something not right when used in conjunction with the skip silence dsp
StJason
The patch seems to work. At least the last couple that I've listened to. *crosses fingers*
This should fix the issue when the silence remover dsp is used in conjunction with the tempo dsp
