Why not have the setting in customize panel?
No it's a custom tag for matrix numbers, but albumartists are showing in that place when no matrix is used
Quote from: johnmillsjr on February 09, 2020, 01:29:15 PMNo it's a custom tag for matrix numbers, but albumartists are showing in that place when no matrix is usedSuggestion: try replacing 'matrix' for another tag in that position. If that works, take a good look at your matrix tag and/or post it here to see if there's a syntax error.
Where would I see syntax errors?
Quote from: johnmillsjr on February 24, 2020, 06:35:25 AMWhere would I see syntax errors?In the custom tag you created: matrix
