Author Topic: Want to improve sort in Album Artist for CJK  (Read 876 times)
daramkun
Now, Album Artist and etc Sorting Alphabet character -> Latin Extension character -> Japanese character(Kana; Hiragana and Katakana) -> Chinese character(Hanja in Korean, Kanji in Japanese) and Korean character(Hangul) mixed. Chinese character and Korean character must separate in sort.
Description Image: https://i.imgur.com/oHX3m18.png
Hi, welcome to the forum!
It's not an ideal solution but you can probably make this work the way you want if you turn on the "custom sorting" option, which is in the Sorting tab of the tag editor. Then you can define the order you want things to sort in by putting numbers or other characters at the beginning of the Sort Artist field.
