Author Topic: Unable to load element: 1067992713 - Object reference not set to an instance of  (Read 2414 times)
foxj
Does anyone know what element this message is barking about?
Unable to load element: 1067992713 - Object reference not set to an instance of an object.
Thanks
that element is "Menu.DropDownSeparator"
however it might be the line in the skin immediately before or after that is the actual problem
send a link to the skin if you cant figure it out
Last Edit: January 15, 2020, 08:01:32 PM by Steven
