Hello Steven,
just updated again to 3.4.8033 and the bug is there again. But this time only for one library at a time, I've got seperate libraries for my MP3's and FLAC's. When I delete my "recently added" tab and add a plain new one (new tab -> playlists -> recently added), it works for the library I've created it in. It shows which albums I've added in the last 7 days and in the last month, in the right order. When I switch to the other library, the sorting there is back to default (or whatever; the sorting is set to manual order), and the headlines "last 7 days" and "last month" are not showing, it all is just out of order. Then I switch back to the other library, in which I've created the tab, and atleast there everything is normal.
Here's my settings file, which has errors:
MusicBee v3.4.8033.18564D (Win10.0), 13 Jan 2022 15:54:
System.ComponentModel.Win32Exception (0x80004005): Der angegebenen Datei ist keine Anwendung zugeordnet
bei System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
bei System.Diagnostics.Process.Start()
bei System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
bei #=zWIZyVUuxNLL39$ggm5ULXcz19Z0b.#=zW0NsoLfpu5F$.#=ziwfYGLA=(#=zqTU3nglKnwb8VWp94Q== #=zaFVWxMw=)
bei #=zWIZyVUuxNLL39$ggm5ULXcz19Z0b.#=zW0NsoLfpu5F$.#=zt$YJoGTrjxm$3QVZjA==(Object #=z09rm0$E=, EventArgs #=z5EKpxKY=)
bei System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
bei System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
bei System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
bei System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
bei System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
bei System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
bei System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
bei System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.ScrollableControl.WndProc(Message& m)
bei System.Windows.Forms.ToolStrip.WndProc(Message& m)
bei System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Cheers
