Author Topic: ADD previous entries to fields if text already ented like in genre list  (Read 1557 times)
wobbly
eg GROUPING TAG  atm my GROUPING TAG is used for album type :
studio album
live album
single
compilation album
and so on
atm i need to type full name in field every time can you please make all fields  remember previous entries  thanks
My grouping tag already does this, as do most fields.  What version of MB are you using?
wobbly
 i am talking about in the tag editor unless iam looking in the wrong place?  if i edit album  if there is a better way to set grouping tag  let me know thanks
You mean like this, right?
wobbly
strange might be working now...  ok   i think i worked out what's going on   it must get the info from what ever library  you have loaded  i  wonder what file is used to store   GROUPING TAG might see if i can find it  and add a bunch
It bases the list off the tags currently in your library. If a tag is removed, you usually have to restart MusicBee before it stops showing up
