Author Topic: Change ban icon  (Read 5361 times)
diego
Is it possible to change the ban icon? I couldn't find anything about it.
Changing the position and color would be enough for me.
It seems to work when you add references to it under 'TrackLove' like this:
<element id="TrackLove" parent="Panel">
  <left relativeTo="TrackRating.Left" offset="-28" />
  <top relativeTo="Panel.Bottom" offset="-24" />
  <images category="NotLoved"
    default="Images\LastFmNotLove.png"
    highlight="Images\LastFmNotLoveBright.png"
  <images category="Loved"
    default="Images\LastFmLove.png"
    <images category="Banned"
    default="Images\Banned.png"
    highlight="Images\BannedHighlight.png"
</element>
Since a track can't both be Loved and Banned at the same time it will have the same position as 'Loved'.
The 'ban' feature doesn't seem very popular though. I just looked for the shortcut key to easily set a track to 'Banned' but it looks like it doesn't exists, nor a.f.a.i.k. has it ever been asked for.
diego
omg i can't believe i didn't think of that, thank you!
i think the only one is shift + click on the love icon
Well, you are the first person to give that icon any consideration and I don't think it is documented anywhere at all.
So, a good find and you could very well become the first one who publishes a skin using it...
Herchi
I normally use the "Royal blue" skin.
I imagine that it will be adding at the end of the Royal Blue.xml the suggested content as in the image.
add the code as a new 'element' in the xml as in the attached image.
I do not understand what is the use of adding the operation of the 'last fm', it takes out a heart but disabled. I have tried to give the button a normal click and with the 'shift' but nothing happens.
What is described in this thread pertains to .xmlc (bitmapped) skins only.
It won't work on .xml skins.
Herchi
I had seen that xmlc's cannot been edited: https://getmusicbee.com/forum/index.php?topic=20921.0
I have searched for two skins on the web, in their respective support forum the source code to edit it and add these blessed lines but I have not found it. (And I would still be missing the path to compile it)
I would ask someone to share a dark skin with the ban icon, please. I just want that and I see such a mess.
This was said in this thread:
No skin has been released that uses a customised ban icon yet.
If having a customised ban icon is that important to you, you will have to create an .xmlc skin yourself.
Find a dark .xml skin that you like, modify it to add your 'ban' icon, and then compile it into an .xmlc skin.
The Incredible Boom Boom
I can add it to my plugin - or we can petition @Steven to incorporate it?
