Author Topic: Add a search field to the settings  (Read 3561 times)
tverderesi
Today I reinstalled musicbee and I haven't exported my configuration snapshot. It took me almost 15 minutes to find where the 'disable half stars' toggle was. I think musicbee, being a extremely customizable program, should have a search field where we could search settings, if the coding for adding this function can be implement with easiness. I always get lost when I have to change some specific setting I haven't touched in months, since I don't change my settings a lot, a search where I could input i.e. 'ratings' and show me all the ratings related settings (like in macos).
+1
In the meantime, you might be able to search the wiki when you're having trouble finding something.  The Preferences pages are pretty complete.
telmer6
+1
MusicBee has a lot of settings. This is good; having more options is always a plus in my book.
They aren't always where I expect them to be. This is annoying.
A search bar (honestly, just a basic case-insensitive match against localized labels would be adequate) would make finding things less frustrating.
+1
Astro Gaze
+1
Something to think about: Not all settings are in the preferences. For example, Compact Player's maximize or restore can only be found in the top left 3 lines, when in Compact Player view. Either include these outliers in the main preferences window, or include a link that sends you there, during a search.
