Author Topic: Message stating 'Device IPOD not ready - please insert and try again'  (Read 584 times)
Fordis80
This has popped up when I try and synch my playlists.
The ipod merely displays a 'connected, eject before disconnecting' message.
I tried a different Ipod because of a strange message popping up when I tried to synch my other Ipod (see my other thread).
This is getting rather absurd.
If I'd have known Music Bee didn't get along with Ipods, I wouldn't have spent hours compiling my playlists and would have stuck with Itunes.
Thanks in advance
If you had done some research first you could've saved yourself a lot of time.
MusicBee doesn't directly support Apple devices. There are a couple of plugins you can try (search the plugin section in the forum) but there are no guarantees that they will work for syncing.
There are no plugins that allow syncing between MB and ipods. But you can search the forum for "ipod" and see some tips and tricks that others have used. They're rather old and may not work with the latest versions of MB and/or iOS.
Last Edit: January 03, 2020, 03:08:40 AM by phred
