Author Topic: MMX  (Read 4558 times)
Clarence
My second skin.
Dark & Light versions.
I hope some of you like it and find it useful.
MMX DARK:
MMX LIGHT:
DOWNLOAD:
MMX Dark
MMX Light
SuperMagicom
This is quite nice. If I have one criticism it's the "MMX" in the bottom left. Would rather it was not there or maybe a Musicbee logo instead. Still a keeper though.
HaaiHenkie
Thanks Clarence for this skin, I really like it.
But I have a request..... and that is: Is it possible to show me the settings (f.e. by an image) of the "Track DJ-panel at the right??
Thanks in advance.
Keep up the good work :-)
Clarence
Hi HaaiHenkie,
I think you are referring to the panel shown in the screenshots above like this.
If so...
Firstly I have Playing Tracks showing in the right sidebar panel which you can select from the Arrange Panels icon or the View menu.
The [DJ] next to the Tracks header shows that AutoDj has been activated by pressing the Shuffle button on the main player and click until the headphone symbol is displayed. You can also activate AutoDj directly from the Controls menu.
You need to have a couple of parameters set for AutoDj and you can do this by right-clicking on the Tracks[DJ] header which will bring up a menu from which you can select Auto-DJ Settings which will in turn open a new tab for the settings screen as below:
On this Screen you can set various parameters for AutoDj.
The example below shows that I want 15 tracks selected when I turn it on and that I want a minimum of 5 tracks to always be available in the Tracks Playing list.  You can also select how 'random' should be treated and various other options. If you click the preview button it will show a list of what's going to be played in the lower part of the panel.
Hope this answers your question and is of help to you.
HaaiHenkie
that's exactly what I meant, thanks for your quick reply
