Author Topic: Tracks are not in right order on the main screen  (Read 1427 times)
HaaiHenkie
After adding an album, it appeared that the songs did not appear in the correct order. What am I doing wrong. Can anyone help me?
I've added a screenshot.
Can you post a screenshot of the settings panel that has your settings for displaying 'tracks directly under the selected album'?
(Or take a good look at those settings, and check the tags of the album, especially where tracks 1-14 differ from 15-19)
Feel free to ignore, the answer seems inadequate.
Last Edit: December 22, 2019, 07:02:05 PM by hiccup
Based on the way those are showing up, I'd take a look at your disc # settings. Make sure the total discs are the same for the whole album, and the disc# is present and correct for each track.
Last Edit: December 23, 2019, 06:06:57 AM by psychoadept
Latest patches (3.5/3.6)
It can't be a coincidence that the tracks #15-19 appearing before the others are the additional tracks on the "Art Book Deluxe Edition" bonus disc.
https://en.wikipedia.org/wiki/Outlaw_Gentlemen_%26_Shady_Ladies
HaaiHenkie
Thanks for your suggestions, there was a fault in the tags :-( So problem fixed.... thanks again
