Author Topic: AIFF files show wrong time duration  (Read 3216 times)
Leroy Bad
MusicBee 3.3.7261 Windows 10 64-bit
Aiff files above 44.1khz , display the lengths of each track as double or more than what they really are.
The run time of this album is 96/24 and runs 66:31, but musicbee is showing 144:48 because of the tracks lengths are greater than they actually are. Files at 44.1khz are displayed correctly.
http://www.mediafire.com/file/kjle6halndvkxne/MusicBee3Settings.ini/file
Last Edit: December 16, 2019, 11:12:56 PM by Leroy Bad
fournier
Leroy Bad
Unfortunately I never got a response to this. And the problems remains in the current version.
can you PM me a link to one of the problem files
Leroy Bad
This should fix the issue:
you need to right click/ send to/ rescan files for the relevant files
Leroy Bad
Thank you for finally looking into it.
After the patch and rescanning the files, it appears to make the tags unreadable.
fournier
Thank you for looking into it.
I also meet the same problem, and ErrorLog.dat shows "File open failed: 'xxxx.aiff' - An attempt was made to move the file pointer before the beginning of the file"
Sorry about that. It should work now if you redownload and then rescan the file(s)
Leroy Bad
You did it! Now everything is the way it should be!
Thank you!
