Author Topic: Rainmeter Plugin  (Read 23232 times)
vpsaxman
Mine's working great.
I have the latest MB with CAD plugin enabled, latest RM and this skin : http://browse.deviantart.com/?qh=&section=&q=leij#/d3r7vqn
The skin is set as "CAD" for the player.
Joergermeister
  • I used to jog...
@Steven. Definetly willing to try out the debug version. Just let me know what to do...
Thanks
keep a copy of your current musicbee.exe file
replace musicbee.exe with this one and then run MB as normal with CAD enabled
then go to help/ support/ view error log and i need the last set of entries dated around the time you run this test
http://www.mediafire.com/?z3irrj9nbu684s0
