- What font is being used on the main screenshot? - Are you considering extending the skin to the compact player layout?
- Is there a chance users could ask you for additional colour themes?
2. I meant when you minimise MB to the 'Compact Player' version, the skin it uses is not 'Material' as it is in Main Player or Mini Player ... (screenshot: https://i.imgur.com/D1MM3Ii.png)
3. I was looking at maybe a darker Blue Grey version, with RGB 52,64,85 (HEX #344055) as the accent colour, and maybe RGB 34,39,48 (HEX #222730) as the background colour, if possible...
