Author Topic: MaterialMix - High DPI Supported  (Read 15659 times)
diego
All 9 colors + icons
>> Download - Source
Last Edit: August 06, 2023, 09:47:23 PM by diego
Nice!
diego
Update v1.1
Adjusted all colors for more legibility
Added two more colors: grey and blue grey
Cheers
spandan888
really good.
link to the addon page is
https://getmusicbee.com/addons/skins/203/materialmix/
use that link in the first post
8) Get the BIGradientz Theater Mode.  8)
diego
I don't understand, you saying that i should use the link to the skin page instead of the direct download link? why?
spandan888
i am saying that because then you would have better statistics of downloads in your dashboard
diego
Nah, its fine. That way is just more clicks for anyone downloading from the forum and mediafire shows download count anyway, all good.
diego
Update v1.2
updated some icons
fixed some colors
added icons for musicbee 3.4
accent color show on more places now (mini player, love icon, spectrum, checkbox, buttons)
added 18 desktop icons
diego
Update v1.3
added segoe ui version
fixed banned and stop buttons
updated icons
added support for high dpi displays
krilok
Thank you for this great skin; it's really well made and has become my new favourite...
Few questions though, if I may...
- What font is being used on the main screenshot?
- Are you considering extending the skin to the compact player layout?
- Is there a chance users could ask you for additional colour themes?
Thanks again...
diego
The font is roboto condensed, it's included in the zip file.
You mean the control buttons, right? Those are hard-coded, it's not possible to change them.
Sorry mate I won't make other color themes. But just out of curiosity, what's the color that you want?
krilok
Hi, Diego,
Thank you for the quick reply...
1. I hadn't enabled the font in settings...  ;)
2. I meant when you minimise MB to the 'Compact Player' version, the skin it uses is not 'Material' as it is in Main Player or Mini Player ... (screenshot: https://i.imgur.com/D1MM3Ii.png)
3. I was looking at maybe a darker Blue Grey version, with RGB 52,64,85 (HEX #344055) as the accent colour, and maybe RGB 34,39,48 (HEX #222730) as the background colour, if possible...
Thanks again!
diego
I didn't test this layout, will fix in the weekend.
This is a very dark color which is not good because of the black icons and text. All the colors that I included has a balance of not too dark and not too bright as well because this is a dark theme.
With this one I would have to change all icons colors to white, add this to the background color and this skin would look completely different so I won't do it, sorry.
krilok
Thanks for the reply...
Regarding the colour combo, that's quite all right, I understand. Hope you can skin the compact player whenever possible. Thanks again.
diego
Update v1.4
fixed compact player colors
fixed colors on tag editor panel, column browser + other small fixes
