Hello everybody, I,m new here
I foolishly removed MusicBee form my Windows 8 laptop and now would like to re-install it again. Using the downloaded file MusicBeeSetup_3_2_Update.exe I get the error message
Unable to access the MusicBee library path: \MusicBee\
UFABET1688Pressing Retry repeats the message, and when I hit Cancel the following ErrorLog.dat file opens
UFA29/01/2019 10:46:38 - 6.3.9600.0 - 3.2.6902.32258 - System.IO.IOException: The filename, directory name, or volume label syntax is incorrect. [\MusicBee\]
at #=zf67MEopCrwJkUkPlGumBqLA=.#=zworXhnS61bwz.#=zxIq5PeQ=.#=zc3YHqDk=(#=zkilhrE$cypVhjQ8q52qKxTQ= #=z0k4Bx$M=, Boolean #=zmFaAsvwdppoG)
at #=zjyXLHZtxcuOO$I_VXEWeIlk=.#=znebkksw=.#=zY$bG2Mw=(#=zkilhrE$cypVhjQ8q52qKxTQ= #=z0k4Bx$M=)
at #=zjyXLHZtxcuOO$I_VXEWeIlk=.#=zyvZgoERts9lF(#=zkilhrE$cypVhjQ8q52qKxTQ= #=z0k4Bx$M=)
at #=zx9H$0K5tc$nGAYtoyncaKErOthcW.Main(String[] args)
29/01/2019 10:46:38 - 6.3.9600.0 - 3.2.6902.32258S - System.IO.IOException: The filename, directory name, or volume label syntax is incorrect. [\MusicBee\]
ยูฟ่าเบทI've tried re-installing and I'm stuck in the same grounghog loop.
Suggestions and ideas are greatly appreciated. Thank in advance.
