Not sure whether to post this in Skins or in Icons, so I'm starting here! I use the latest Dark Fine-Tuned skins which depend on the Onyx.xmlc root. When searching Soundcloud, the results come back with just a pale grey square icon on the left-most column instead of the orange-and-white Soundclud icon on the MusicBee3 default skin. This doesn't bother me, but unfortunately in cases of downloadable files that normally have the "green" lower appendage on the orange icon to easily ID them, they are very hard to spot within the grey version where only a same-color appendage appears:
Is there any way to change those icons to display the original orange/green combo, or is that locked within the Onyx.xmlc in a way that is uneditable via the *.xml companions?
Trying to use a colorpicker on Hiccup's sample skin is not an option because the original icons have a shaded color that changes RGB values as you move within them, and I'm not sure these even ARE skin elements per se.
Any help appreciated! Mods, feel free to move this.
