Author Topic: About the behavior when the playlist folder is moved to another one  (Read 1471 times)
fournier
When the playlist folder is moved to another one, MusicBee shows the behavior which is different than I expected:
The behavior I expected
The actual behavior
Is this a specification or a bug?
Its doing what its programmed to do, but I agree what you say does make more sense. I will see whats involved with changing the behavior
edit:
for the next v3.3 update its changed to behave as you would expect
Last Edit: December 01, 2019, 07:36:01 PM by Steven
fournier
edit:
Thank you so much!
fournier
Thank you! The patched MusicBee shows the behavior which is almost the same as I expected; although it may be a rare use case,
an empty playlist folder is deleted when the folder is moved to another one.
