Author Topic: "Add Radio URL" in Radio page right click context menu is needed  (Read 1146 times)
Arindel
Hello!
As you can see here in the context menu when you right click the Radio area, you can Edit and Remove Radio URLs, but you can't Add one.
Right now the only way to add new radio is to just search a radio in that Icecast/SHOUTcast, add it and then edit it afterwards. This is really a bad way of doing it.
Can we have a "Add Radio URL" option in that right click context menu, please?
If you right-click the Radio header bar, you will already find that choice:
Be sure you're using the latest version of MusicBee.
Arindel
Thank you! It never occured to me to try there. Typically the Add/Edit/Remove are on the context menu of the list area, which is why I only checked there.
Still, would be nice if the Add station is added there for other people that would probably end up as confused as I was.
