I don't want to open another topic as I'm not sure the bahaviour I noticed with the latest build is a bug or it's intended
I selected all the tracks in my testing library and then I've chosen Auto-Tag by Track/ Identify tracks and Update Tags.
The enabled update options were as follows:
- All supported field except Artwork and Lyrics;
- restrict release types: album;
- retrieve multiple genres for each track to a maximum of 3 genres.
Most files were updated successfully. However, for about 10% of the files I can see the error:
"Web-service failed with error: Protocol error - please try again". I've never seen this command before so the above question arises.
BTW, Is it possible to redo the update but only for the files that have reported the above error in the status field
A
Redo button would be appreciated for the files with "No changes", "Failed: Unable to match the name of the track" or the mentioned above error status.
Furthermore,
the Auto-Tagger window should be auto-adjustable, because in order to read the whole message in the Status field log I have to hover the mouse indicator over it and there is enough free space in neighbouring "Name" field that is wasted.
