Author Topic: error 1393  (Read 721 times)
olinto
Hi
I have a problem,
1. when making manual updates, upon closing the program it advises as error to" replace 1393" and it fails to update the change
2. The inbox is empty, hoever it shows a 6715.
how can I rectify without having to download the new version.
Hi, welcome to the forum!
You can't, this is a bug that was fixed in newer versions. Are you saying you're getting the error message when trying to update? What version do you have? (Regular, portable, Windows Store?)
olinto
hi,
I have the regular version from 2 years ago. the notice appears when you exit musicbee stating that it didn't save.
Yeah, in that case the solution is definitely to upgrade. If you're still getting any errors after that, Steven might be able to address them. There are instructions on the wiki for making backups if you're concerned about losing settings.
