Author Topic: Dark W10 - High DPI Supported  (Read 28061 times)
diego
Updated the source for anyone who wants to make their own skin, but please if you're gonna use the images from these skins at least give me the credits, cheers!
Musicmouche
It's a nice skin, is it possible to make a white version?  :)
diego
I'm not gonna make one, sorry.
diedie2
I must be doing something wrong bc I can't get the icons to become visible :-(
There also seems a little bug as artist and title are not good aligned on the bottom of the screen (should be left, next to buttons or centered I think)
diego
Enable the progress bar. Right click the panel > panel layout > show progress bar. It doesn't work nice without.
diedie2
Ok, got it working. Also the icons next to "music", "now playing", "podcast", I managed to enable them.
But the icons next to artist, album, bitrate....I can't find it...
diego
https://getmusicbee.com/forum/index.php?topic=30472.0
diedie2
oh, I thaught it was part of the skin lol
tnx mate!
MusicSnooper
What's the code for the bitrate to include it into the track info window ?
diego
{font: Segoe MDL2 Assets;Regular;12}{contrast: 50} {font: Roboto Condensed;Regular;10}{contrast: 90}{color: 240,240,240} <Bitrate>
wealstarr
Absolutely wonderful stuff. Good job diego.
One request, will it be possible for you to to make a variant with auto hiding of scroll bars and show only when hovered upon ?
In any case, big thanks!
Love those Icons.
Edit: noticed a potential bug.
With the track information panel header being hidden, there's band of the header still visible.
Last Edit: November 12, 2020, 12:57:38 PM by wealstarr
diego
Download this and put on the same folder that you have the skin (.xmlc file) installed:
https://gist.githubusercontent.com/diego-sergio/1a15bea4367ccdad9b9ce3bfe205b97a/raw/febb5903d811f09191513c1af9603536d42f86e6/Dark%20W10%20-%20Transparent%20Scrollbars.xml
Change the line <root dependsOn="Dark W10 - Roboto - Purple.xmlc"> to the skin variation that you're using (it needs to be exactly the same name).
This is normal, it follows the color of the header, if you want to change that follow hiccup's guide:
https://getmusicbee.com/forum/index.php?topic=29815.0
wealstarr
@diego Thanks! Appreciated  :-*
Edit: Got the error, player won't start and throws this
12-11-2020 22:59:38 - Unable to load dependency: Dark W10.xmlc - The system cannot find the file specified. [C:\Users\wealstarr\AppData\Roaming\MusicBee\Skins\Dark W10.xmlc]
12-11-2020 22:59:39 - 6.3.9600.0 - 3.3.7367.38620D - System.TypeInitializationException: The type initializer for '#=zSY5hHAbHQ4EHcR39WuTgwzM=' threw an exception. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at #=zSY5hHAbHQ4EHcR39WuTgwzM=.#=zZBCS58hlFZ5J(Bitmap #=zcZyEZeQ=, Size #=zvuCf96g=, Boolean #=zcS5Ok0Q=)
   at #=zSY5hHAbHQ4EHcR39WuTgwzM=..cctor()
   at #=zSY5hHAbHQ4EHcR39WuTgwzM=..ctor(Boolean #=z1UAzKztWafhh_iseWA==, Boolean #=zJnrDgZshgtK6)
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u..ctor()
   at #=zADbnadLxl1TKH02_Qzso3yQ4IyJJ.Main(String[] args)
Could it be because I renamed the file ?
Last Edit: November 12, 2020, 05:34:15 PM by wealstarr
diego
probably, that's why i said it the name of the skin in the xml needs to be the same name as the skin file.
