Author Topic: Dark W10 - High DPI Supported  (Read 28120 times)
diego
Include 4 colors: blue, green, purple and grey, some desktop icons and a simple theater mode.
>> Download - Source
Thanks to:
endeavour1934 for source of DarkRED
hiccup for Sample Skin
sveakul for Base64encode
Last Edit: August 06, 2023, 09:48:30 PM by diego
Looks great and feel free to submit it to the Add-Ons page
diego
Will do when i finish, there's more stuff to do. Like this drive icon:
is it possible to change the icon or color?
And thanks for this great player man, it's crazy how many features it has!
Last Edit: January 04, 2020, 03:43:40 AM by diego
Congrats with the skin, nice work.
There are five new elements for several drive icons. They are:
NetworkDriveIcon - network share
WpdDeviceIcon - portable devices (WPD and ipod)
UsbDeviceIcon - usb devices
StorageIcon - for all other root drives eg. virtual drive
OpticalDriveIcon - for optical drives
Note that they will not show up in current MusicBee releases, only in upcoming MB 3.4.
link to related thread:
https://getmusicbee.com/forum/index.php?topic=29451.msg164278#msg164278
diego
Ok got it, thank you.
Mobbsypom
Just wanted to say...love the skin..brilliant..thanks
diego
Updated:
Fixed some icons and other stuff
Added some desktop icons
3 colors options to use now: green, purple or grey
ner0
Amazing work, thank you for sharing it with us!
Also using it right now and loving it.  ;D
Noctale
This is an awesome skin, exactly what I've been looking for! It fits so well with everything else dark in Windows 10, particularly the grey one for me.
diego
Update v1.1:
Disabled the borders
Changed more icons
Moved the love icon to the right side (if you choose to hide the icon, the progress bar and time will not move leaving a blank space instead. i will update when i figure out how to fix)
Cheers everyone.
I've been wanting to try this, but when I go to download it I get a message that the page isn't found. (I can get to the site, just not the download.)
diego
Goddamnit, i think deviantart changed something in the backend. Changed to mediafire.
Thanks! That seems to have done it.
diego
Update v1.2
Fixed progress bar position
Enabled track details on multiple lines
Fixed some colors
Added a simple TheaterMode.Embeded with cover and lyrics
Update v1.3
just a small one to fix the misaligned time
Last Edit: December 01, 2019, 09:10:18 PM by diego
Ansem
Really great skins!
I have only one question: I installed the 4 Roboto Fonts that cam with the skin, but I'm not sure where should I use them.
Could you post a screenshot about where should I put them?
