I am a fairly basic MusicBee user since about a year and I am contemplating an update to a later MusicBee version. I have several basic questions:
1. How do I know which MB version I currently have? I don't see any "About.." in any drop-down menu. I thought I might get an indication by looking for the MB installation files in C:\Program\Program files folder or c:\Program Files(x86) folder, but no such thing. I finally found folder "50072StevenMayall.MusicBee_kcr266et74avj" in the C:\User\me\AppData\Local\Packages folder. I am guessing from the folder name that this is version 2.66, but why this uncommon location for the installation?
2. When I download and install the latest version, will MB retain my panel layout, library content, filter and other settings such as preferred Player? I see MB files in my Music\MusicBee folder which is separate from the MB installation folder so I hope that after new installation MB will read those files.
3. Where will the latest version be installed?
4. Does the latest version display MB version and is there a feature to "Check for updates on Start-up" or other means to update MB from within MB.
5. Should I download the latest version from Microsoft Store or from MB site? Pros, cons?
Thank you for your help
